跳转到主内容
Motorola Slvr L7 Camera Assembly Replacement
你所需要的
  1. Motorola Slvr L7 Camera Assembly Replacement, Camera Assembly: 步骤 1 中的图像 1,1
    • To ensure safety, discharge your phone battery below 25% before starting. A fully charged lithium-ion battery may cause a fire and/or explosion due to defects or damage.
    • Turn off your phone before beginning disassembly.
    • To replace the camera, first begin by removing the battery.
    • Push down on the black tab at the Motorola phone’s top center to detach the back phone cover and access the battery.
  2. Motorola Slvr L7 Camera Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the battery on the back of the Motorola phone by pulling it away from the back of the phone.
  3. Motorola Slvr L7 Camera Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  4. Motorola Slvr L7 Camera Assembly Replacement: 步骤 4 中的图像 1,2 Motorola Slvr L7 Camera Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the metal cover by inserting the flat end of the iFixit Opening Tool under the side of the cover, prying it away from the phone.
  5. Motorola Slvr L7 Camera Assembly Replacement: 步骤 5 中的图像 1,2 Motorola Slvr L7 Camera Assembly Replacement: 步骤 5 中的图像 2,2
    • Carefully separate the two connectors from their sockets on the motherboard using the flat end of the iFixit Opening Tool, so the two connectors are open.
  6. Motorola Slvr L7 Camera Assembly Replacement: 步骤 6 中的图像 1,2 Motorola Slvr L7 Camera Assembly Replacement: 步骤 6 中的图像 2,2
    • Use the flat end iFixit Opening Tool to pry the antenna cable connectors from their respective sockets on the motherboard.
    • Pull the antenna cable out to de-route it from the phone.
结论
Jorge Trujillo
于05/19/11注册
520 声望
创作了4篇指南
团队
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G1
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,995
