跳转到主内容
Motorola SURFboard SB5101 Standby Key Replacement
你所需要的
  1. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 步骤 1 中的图像 1,3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 步骤 1 中的图像 2,3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 步骤 1 中的图像 3,3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 步骤 2 中的图像 1,3 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 步骤 2 中的图像 2,3 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 步骤 2 中的图像 3,3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 步骤 3 中的图像 1,3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 步骤 3 中的图像 2,3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 步骤 3 中的图像 3,3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: 步骤 4 中的图像 1,2 Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: 步骤 4 中的图像 2,2
    • Position the small black standby in the opening at the top of the case such that the wider teeth of the key is facing up.
    • Gently lower the key so the narrow teeth of the key are resting on the notch (circled in red) just below the opening at the top of the case.
    • If you plan to continue working on the device, check that this key is in place before finally closing the device.
结论
Your standby key has been successfully realigned.
2等其他人完成本指南。
Bhavik Patel
于10/13/14注册
276 声望
创作了2篇指南
团队
Clemson, Team 1-2, Benson Fall 2014 Clemson, Team 1-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,019
