跳转到主内容
Motorola SLVR L9 Front Panel Replacement
你所需要的
  1. Motorola SLVR L9 Front Panel Replacement, Battery: 步骤 1 中的图像 1,2 Motorola SLVR L9 Front Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Front Panel Replacement: 步骤 2 中的图像 1,3 Motorola SLVR L9 Front Panel Replacement: 步骤 2 中的图像 2,3 Motorola SLVR L9 Front Panel Replacement: 步骤 2 中的图像 3,3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Front Panel Replacement: 步骤 3 中的图像 1,3 Motorola SLVR L9 Front Panel Replacement: 步骤 3 中的图像 2,3 Motorola SLVR L9 Front Panel Replacement: 步骤 3 中的图像 3,3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: 步骤 4 中的图像 1,2 Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: 步骤 4 中的图像 2,2
    • Turn the phone over so that the back of the phone is facing towards you.
  5. Motorola SLVR L9 Front Panel Replacement: 步骤 5 中的图像 1,3 Motorola SLVR L9 Front Panel Replacement: 步骤 5 中的图像 2,3 Motorola SLVR L9 Front Panel Replacement: 步骤 5 中的图像 3,3
    • Press down on the battery cover latch located at the top of the phone.
  6. Motorola SLVR L9 Front Panel Replacement: 步骤 6 中的图像 1,1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  7. Motorola SLVR L9 Front Panel Replacement: 步骤 7 中的图像 1,2 Motorola SLVR L9 Front Panel Replacement: 步骤 7 中的图像 2,2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
  8. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: 步骤 8 中的图像 1,3 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: 步骤 8 中的图像 2,3 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
  9. Motorola SLVR L9 Front Panel Replacement, Front Panel: 步骤 9 中的图像 1,1
    • Use a screwdriver with a T6 Torx screwdriver head to turn the screw counter-clockwise (left).
  10. Motorola SLVR L9 Front Panel Replacement: 步骤 10 中的图像 1,3 Motorola SLVR L9 Front Panel Replacement: 步骤 10 中的图像 2,3 Motorola SLVR L9 Front Panel Replacement: 步骤 10 中的图像 3,3
    • Using the grooves around the edge of the phone, gently pull the front panel away from the phone until it is fully removed from the device.
结论
Ivan Sarabia
于10/13/15注册
104 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 177
