跳转到主内容
Motorola Razr V3m Speaker Replacement
你所需要的
  1. Motorola Razr V3m Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Razr V3m Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Speaker Replacement: 步骤 2 中的图像 1,2 Motorola Razr V3m Speaker Replacement: 步骤 2 中的图像 2,2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Speaker Replacement, SIM Card: 步骤 3 中的图像 1,2 Motorola Razr V3m Speaker Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Speaker Replacement, Antenna: 步骤 4 中的图像 1,2 Motorola Razr V3m Speaker Replacement, Antenna: 步骤 4 中的图像 2,2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Speaker Replacement: 步骤 5 中的图像 1,1
    • Carefully use a plastic opening tool to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Speaker Replacement: 步骤 6 中的图像 1,2 Motorola Razr V3m Speaker Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Speaker Replacement: 步骤 7 中的图像 1,1
    • Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
  8. Motorola Razr V3m Speaker Replacement: 步骤 8 中的图像 1,2 Motorola Razr V3m Speaker Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to pry the edge of the antenna away from back panel.
    • The antenna may be fastened with two grey clips on either side. If this is so, unfasten two plastic clips located on the edge of the antenna.
    • Lift antenna away from back panel.
  9. Motorola Razr V3m Speaker Replacement, Speaker: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • The Speaker is the round piece located beneath the antenna.
    • Use tweezers to remove the speaker.
结论
Daniel Simcock
于10/24/15注册
731 声望
创作了6篇指南
团队
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 247
