跳转到主内容
Motorola Razr V3m Screen/Camera Replacement
你所需要的
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Razr V3m Screen/Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: 步骤 2 中的图像 1,2 Motorola Razr V3m Screen/Camera Replacement: 步骤 2 中的图像 2,2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: 步骤 3 中的图像 1,2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: 步骤 3 中的图像 2,2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: 步骤 6 中的图像 1,1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: 步骤 7 中的图像 1,2 Motorola Razr V3m Screen/Camera Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
结论
另外一个人完成了本指南。
Daniel Simcock
于10/24/15注册
731 声望
创作了6篇指南
团队
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G2
4 名成员
创作了7篇指南
一条评论
where can this part be purchased?
Alex Alexander - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 417
