跳转到主内容
Motorola Razr V3m Keypad Cover Replacement
你所需要的
  1. Motorola Razr V3m Keypad Cover Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Keypad Cover Replacement: 步骤 2 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement: 步骤 2 中的图像 2,2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Keypad Cover Replacement, SIM Card: 步骤 3 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 步骤 4 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 步骤 4 中的图像 2,2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Keypad Cover Replacement: 步骤 5 中的图像 1,1
    • Carefully use a metal spudger to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Keypad Cover Replacement: 步骤 6 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Keypad Cover Replacement: 步骤 7 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement: 步骤 7 中的图像 2,2
    • Use a T6 Torx bit screwdriver to remove the two screws holding the cover down.
    • The metal shield will come off with the screws; don't forget to reattach it before replacing the screws.
  8. Motorola Razr V3m Keypad Cover Replacement: 步骤 8 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement: 步骤 8 中的图像 2,2
    • Remove the keypad cover, located below the keypad on the front of the phone.
  9. Motorola Razr V3m Keypad Cover Replacement: 步骤 9 中的图像 1,2 Motorola Razr V3m Keypad Cover Replacement: 步骤 9 中的图像 2,2
    • Remove the sticker on the back of the phone.
  10. Motorola Razr V3m Keypad Cover Replacement: 步骤 10 中的图像 1,3 Motorola Razr V3m Keypad Cover Replacement: 步骤 10 中的图像 2,3 Motorola Razr V3m Keypad Cover Replacement: 步骤 10 中的图像 3,3
    • Using a plastic opening tool, push the four metal tabs along the edge of the phone in towards the keypad.
  11. Motorola Razr V3m Keypad Cover Replacement: 步骤 11 中的图像 1,3 Motorola Razr V3m Keypad Cover Replacement: 步骤 11 中的图像 2,3 Motorola Razr V3m Keypad Cover Replacement: 步骤 11 中的图像 3,3
    • Using the plastic opening tool, pry the edges of the keypad until it is loose. Then, pull it off.
    • It is easiest to work your way from left to right when loosening the case.
结论
另外一个人完成了本指南。
Jonathan Gendron
于10/28/15注册
122 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 1,056
