跳转到主内容
Motorola Razr V3c Upper Casing (CDMA) Replacement
你所需要的
  1. Motorola Razr V3c Upper Casing (CDMA) Replacement, Upper Casing (CDMA): 步骤 1 中的图像 1,1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Upper Casing (CDMA) Replacement: 步骤 2 中的图像 1,1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Upper Casing (CDMA) Replacement: 步骤 3 中的图像 1,1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Upper Casing (CDMA) Replacement: 步骤 4 中的图像 1,3 Motorola Razr V3c Upper Casing (CDMA) Replacement: 步骤 4 中的图像 2,3 Motorola Razr V3c Upper Casing (CDMA) Replacement: 步骤 4 中的图像 3,3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
结论
4等其他人完成本指南。
krisko
于01/14/10注册
104 声望
创作了4篇指南
团队
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 5,219
