当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the four rubber pieces from all corners of the area around the screen.
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
Be sure that you do not strip or damage the screws.
Carefully pry the screen away from the phone using a plastic spudger.
Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Take the screen housing off of the casing.
Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Pry screen cover off with plastic opening tool.
The screen cover has some adhesive holding it to the screen.
Remove small black sticker covering the camera ribbon connector.
Flip over small hinge that covers the camera ribbon connection.
Pull off the rubber camera cover and camera.
The camera and camera cover may come off either separately or together.
Disconnect the metallic ribbon cover.
Remove and replace the screen.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与6其他贡献者
于01/14/10注册
506 声望
创作了4篇指南
徽章: 10
+ 7更多徽章
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
Is it a T5 or a T4 for removing the screws?
Francis Reyes - 2012年11月12日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 12
总计 9,400
