跳转到主内容
Motorola Razr V3c Screen (CDMA) Replacement
你所需要的
  1. Motorola Razr V3c Screen (CDMA) Replacement, Upper Casing (CDMA): 步骤 1 中的图像 1,1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 2 中的图像 1,1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 3 中的图像 1,1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 4 中的图像 1,3 Motorola Razr V3c Screen (CDMA) Replacement: 步骤 4 中的图像 2,3 Motorola Razr V3c Screen (CDMA) Replacement: 步骤 4 中的图像 3,3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  5. Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 步骤 5 中的图像 1,2 Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 步骤 5 中的图像 2,2
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
  6. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 6 中的图像 1,1
    • Remove small black sticker covering the camera ribbon connector.
  7. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 7 中的图像 1,1
    • Flip over small hinge that covers the camera ribbon connection.
  8. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 8 中的图像 1,3 Motorola Razr V3c Screen (CDMA) Replacement: 步骤 8 中的图像 2,3 Motorola Razr V3c Screen (CDMA) Replacement: 步骤 8 中的图像 3,3
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
  9. Motorola Razr V3c Screen (CDMA) Replacement, Screen (CDMA): 步骤 9 中的图像 1,1
    • Disconnect the metallic ribbon cover.
  10. Motorola Razr V3c Screen (CDMA) Replacement: 步骤 10 中的图像 1,2 Motorola Razr V3c Screen (CDMA) Replacement: 步骤 10 中的图像 2,2
    • Remove and replace the screen.
终点
另外一个人完成了本指南。
Joshua Ruehlig
于01/14/10注册
506 声望
创作了4篇指南
团队
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
一条评论
Is it a T5 or a T4 for removing the screws?
Francis Reyes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 9,390
