当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Unscrew the two screws in the back using the T6.
Use the plastic opening tool to pop the bottom and the sides off the back casing.
Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
Peel off the connector between the motherboard and the body of the phone.
Pull out the two black rubber covers using tweezers.
The second rubber cover is much harder to get out.
Pull out the white plastic cover by unclipping the two plastic pieces shown.
Pull out the speaker.
Pull out the motherboard.
You may also now replace the bottom lower casing
取消:我没有完成这个指南。
6等其他人完成本指南。
与3其他贡献者
于01/14/10注册
506 声望
创作了4篇指南
徽章: 10
+ 7更多徽章
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 6,691
