跳转到主内容
Motorola Razr V3c Motherboard (CDMA) Replacement
你所需要的
  1. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 步骤 1 中的图像 1,3 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 步骤 1 中的图像 2,3 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 步骤 1 中的图像 3,3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 2 中的图像 1,2 Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Motherboard (CDMA) Replacement, Speaker (CDMA): 步骤 3 中的图像 1,1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 5 中的图像 1,1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 6 中的图像 1,2 Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 7 中的图像 1,2 Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 7 中的图像 2,2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Motherboard (CDMA) Replacement: 步骤 8 中的图像 1,1
    • Pull out the speaker.
  9. Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): 步骤 9 中的图像 1,2 Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): 步骤 9 中的图像 2,2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
结论
6等其他人完成本指南。
Joshua Ruehlig
于01/14/10注册
506 声望
创作了4篇指南
团队
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 6,717
