简介
This guide will show you how to remove the motherboard on a Motorola V3c.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Unscrew the two screws in the back using the T6.
    • Unscrew the two screws in the back using the T6.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  6. Peel off the connector between the motherboard and the body of the phone.
    • Peel off the connector between the motherboard and the body of the phone.
  7. Pull out the two black rubber covers using tweezers. The second rubber cover is much harder to get out.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  8. Pull out the white plastic cover by unclipping the two plastic pieces shown. Pull out the white plastic cover by unclipping the two plastic pieces shown.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  9. Pull out the speaker.
    • Pull out the speaker.
  10. Pull out the motherboard. You may also now replace the bottom lower casing
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
结论
6等其他人完成本指南。
Joshua Ruehlig
于2010年01月14日注册
503 信誉积分
创作了4篇指南
团队
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G4
3 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 6,405
