跳转到主内容
Motorola Razr V3c Face-Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Motorola Razr V3c Face-Screen Replacement, Face-Screen: 步骤 1 中的图像 1,1
    • Clear a table or desk to use as a workspace. You will need a container to place small screws as they will be used in reassembly.
  2. Motorola Razr V3c Face-Screen Replacement: 步骤 2 中的图像 1,1
    • Open the phone's face.
  3. Motorola Razr V3c Face-Screen Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four screws located around the face plate using a 1.5mm Hex tool.
  4. Motorola Razr V3c Face-Screen Replacement: 步骤 4 中的图像 1,1
    • After removing the screws, use a flat surfaced tool to take the face-screen off.
  5. Motorola Razr V3c Face-Screen Replacement: 步骤 5 中的图像 1,1
    • Use this step as a checkpoint. Once the face-screen cover is off, the workspace should resemble this step’s picture.
  6. Motorola Razr V3c Face-Screen Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the face-screen using your fingers.
  7. Motorola Razr V3c Face-Screen Replacement: 步骤 7 中的图像 1,1
    • You may now carefully install a functioning face-screen.
  8. Motorola Razr V3c Face-Screen Replacement: 步骤 8 中的图像 1,1
    • After securing the face-screen into the casing, place the face screen cover back on.
  9. Motorola Razr V3c Face-Screen Replacement: 步骤 9 中的图像 1,1
    • Screw in the four corner screws. After completion of this step, your phone should function properly. Enjoy!
结论
Enjoy your newly inserted face-screen.
Nigel
于09/06/11注册
133 声望
创作了2篇指南
团队
Cuesta, Team 1-5, Zipperian Fall 2011 Cuesta, Team 1-5, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G5
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,822
