跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Motorola Razr V3 LCD Screens and Call Speaker Replacement
你所需要的
  1. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 2 中的图像 1,2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Upper Casing: 步骤 3 中的图像 1,1
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
  6. Motorola Razr V3 LCD Screens and Call Speaker Replacement, LCD Screens and Call Speaker: 步骤 6 中的图像 1,1
    • Use the spudger to pry off the plastic lens that covers the LCD screen.
    • You will feel some resistance due to the adhesive put in between the screen and the plastic lens. Be careful not to damage the LCD screen.
    • When reassembling, put the screen lens on last. It is much easier to align the lens when you use the upper casing as a guide.
  7. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 7 中的图像 1,1
    • Use the tweezers to gently pry the silver ribbon cable up towards you.
    • Be careful not to damage the ribbon cable when pulling it off, as it can be fragile.
  8. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 8 中的图像 1,2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 8 中的图像 2,2
    • Use he tweezers to flip up the tab.
    • With the tab up, gently pull the copper ribbon cable out.
    • Be careful not to damage the ribbon cable when pulling it out, as it is fragile.
  9. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 9 中的图像 1,2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 9 中的图像 2,2
    • Use the tweezers to gently fold the buttons away from the phone.
    • Be careful not to rip buttons off of the board. You will feel some resistance from the adhesive, but they should easily fold up if they are pulled from the bottom.
    • Use the spudger the speaker from the phone.
  10. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 10 中的图像 1,2 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 步骤 10 中的图像 2,2
    • Place your thumb on the screen and gently push into the phone.
    • It should come out pretty easy. If it is not budging go back and check over the steps again.
结论
6等其他人完成本指南。
Christian
于04/18/13注册
224 声望
创作了2篇指南
团队
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G46
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 9,451
