跳转到主内容
Motorola RIZR Z3 Motherboard Replacement
你所需要的
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Motherboard Replacement: 步骤 2 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Motherboard Replacement: 步骤 4 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Motherboard Replacement: 步骤 6 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Motherboard Replacement: 步骤 7 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Motherboard Replacement: 步骤 8 中的图像 1,2 Motorola RIZR Z3 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
结论
团队
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,321
