跳转到主内容
Motorola RAZR2 v9m SD Card Replacement
  1. Motorola RAZR2 v9m SD Card Replacement, Battery: 步骤 1 中的图像 1,2 Motorola RAZR2 v9m SD Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
  2. Motorola RAZR2 v9m SD Card Replacement: 步骤 2 中的图像 1,3 Motorola RAZR2 v9m SD Card Replacement: 步骤 2 中的图像 2,3 Motorola RAZR2 v9m SD Card Replacement: 步骤 2 中的图像 3,3
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
  3. Motorola RAZR2 v9m SD Card Replacement: 步骤 3 中的图像 1,2 Motorola RAZR2 v9m SD Card Replacement: 步骤 3 中的图像 2,2
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
  4. Motorola RAZR2 v9m SD Card Replacement: 步骤 4 中的图像 1,2 Motorola RAZR2 v9m SD Card Replacement: 步骤 4 中的图像 2,2
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
  5. Motorola RAZR2 v9m SD Card Replacement, SD Card: 步骤 5 中的图像 1,2 Motorola RAZR2 v9m SD Card Replacement, SD Card: 步骤 5 中的图像 2,2
    • Press the exposed portion of the SD card towards the bottom of the phone until you hear a click. The SD card will slide into the phone about 10 mm.
  6. Motorola RAZR2 v9m SD Card Replacement: 步骤 6 中的图像 1,2 Motorola RAZR2 v9m SD Card Replacement: 步骤 6 中的图像 2,2
    • Release the SD card. A spring will push it partially out of the phone.
    • Grasp the card by the edges and remove.
    • When installing a new SD card, remember that it must be 2 GB or less.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 788
