跳转到主内容
Motorola RAZR V3i Battery Replacement
你所需要的
  1. Motorola RAZR V3i Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: 步骤 2 中的图像 1,3 Motorola RAZR V3i Battery Replacement: 步骤 2 中的图像 2,3 Motorola RAZR V3i Battery Replacement: 步骤 2 中的图像 3,3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: 步骤 3 中的图像 1,3 Motorola RAZR V3i Battery Replacement: 步骤 3 中的图像 2,3 Motorola RAZR V3i Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
终点
5等其他人完成本指南。
Nigel
于09/06/11注册
133 声望
创作了2篇指南
团队
Cuesta, Team 1-5, Zipperian Fall 2011 Cuesta, Team 1-5, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G5
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 56
总计 7,182
