简介
This is a guide for replacing the battery of a Motorola RAZR V3i. With time, the battery life decreases and cannot work as efficiently as it did when first purchased. Replace your battery when your phone is no longer holding a charge, when it is dying rapidly after minimal change in use, and/or if the battery is swollen. Make sure the battery is completely discharged before attempting to do this replacement. Be careful to not puncture the battery, under any circumstances. If the battery is swollen, take extra precautions, as this is a sign of a damaged battery. Use protective equipment such as eye protection and gloves. Do not expose the battery to heat or moisture. Consider professional help if you have any issues.
你所需要的
Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
5等其他人完成本指南。
