跳转到主内容
Motorola Q700 Sidekick Speaker and Camera Replacement
你所需要的
  1. Motorola Q700 Sidekick Speaker and Camera Replacement, Phone: 步骤 1 中的图像 1,1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 2 中的图像 1,1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 3 中的图像 1,1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 4 中的图像 1,1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 5 中的图像 1,1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 6 中的图像 1,1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 7 中的图像 1,1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Speaker and Camera Replacement, Speaker and Camera: 步骤 8 中的图像 1,1
    • complete dissassembly as instructed by guide
  9. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 9 中的图像 1,1
    • Remove camera piece from casing
  10. Motorola Q700 Sidekick Speaker and Camera Replacement: 步骤 10 中的图像 1,1
    • replace with new camera piece into casing and reassemble by reversing dissemble procedure
结论
Rich
于04/08/13注册
125 声望
创作了6篇指南
团队
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013 的会员
SUNYCORT-GETTO-S13S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 203
