当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
Separate the front plate from the circuit board.
The LCD screen is attached to the circuit board by a thin ribbon.
Switch the lock on top of the circuit entry from horizontal to vertical.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
