跳转到主内容
Motorola Q Global Display screen Replacement
你所需要的
  1. Motorola Q Global Display screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Display screen Replacement: 步骤 2 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 2 中的图像 2,2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Display screen Replacement, Display screen: 步骤 3 中的图像 1,1
    • Press inwardly on the upper casing to release.
  4. Motorola Q Global Display screen Replacement: 步骤 4 中的图像 1,1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Display screen Replacement: 步骤 5 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 5 中的图像 2,2
    • Remove the 6 screws using the T5 torx screwdriver.
  6. Motorola Q Global Display screen Replacement: 步骤 6 中的图像 1,1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Display screen Replacement: 步骤 7 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 7 中的图像 2,2
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Display screen Replacement: 步骤 8 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 8 中的图像 2,2
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Display screen Replacement: 步骤 9 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 9 中的图像 2,2
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  10. Motorola Q Global Display screen Replacement: 步骤 10 中的图像 1,2 Motorola Q Global Display screen Replacement: 步骤 10 中的图像 2,2
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  11. Motorola Q Global Display screen Replacement: 步骤 11 中的图像 1,1
    • Insert the new LCD screen into the circuit.
结论
Will Dickman
于09/27/12注册
28 声望
创作了3篇指南
团队
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G31
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 827
