跳转到主内容
Motorola Photon 4G MB855 Motherboard Replacement
你所需要的
  1. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: 步骤 1 中的图像 1,2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: 步骤 2 中的图像 1,2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 步骤 3 中的图像 1,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 步骤 3 中的图像 2,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 步骤 3 中的图像 3,3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 步骤 4 中的图像 1,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 步骤 4 中的图像 2,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 步骤 4 中的图像 3,3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 步骤 5 中的图像 1,3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 步骤 5 中的图像 2,3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 步骤 5 中的图像 3,3
    • Locate the Display Data Cables
    • Use hands or plastic opening tool to carefully pry off the connectors.
  6. Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 步骤 6 中的图像 1,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 步骤 6 中的图像 2,3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 步骤 6 中的图像 3,3
    • Be careful when removing the motherboard. The earpiece is connected with small wires and adhesive. Use a thin tool to pry it off before removing the motherboard.
    • Use a plastic opening tool to gently pry off each section of the Motherboard.
    • Slowly and carefully remove the motherboard from the front panel assembly.
结论
4等其他人完成本指南。
Eddie Krause
于10/07/14注册
260 声望
创作了3篇指南
团队
USF Tampa, Team 8-6, Leahy Fall 2014 USF Tampa, Team 8-6, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 15
总计 1,373
