跳转到主内容
Motorola Nextel i880 Key Pad Replacement
你所需要的
  1. Motorola Nextel i880 Key Pad Replacement, Key Pad: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding the clip and lifting up the bottom of the cover.
  2. Motorola Nextel i880 Key Pad Replacement: 步骤 2 中的图像 1,2 Motorola Nextel i880 Key Pad Replacement: 步骤 2 中的图像 2,2
    • Remove screws 1 through 4.
  3. Motorola Nextel i880 Key Pad Replacement: 步骤 3 中的图像 1,1
    • Once all four screws are removed, you should be able to pop off the back half of the phone.
  4. Motorola Nextel i880 Key Pad Replacement: 步骤 4 中的图像 1,1
    • Flip the logic board up to reveal the back of the keypad.
  5. Motorola Nextel i880 Key Pad Replacement: 步骤 5 中的图像 1,1
    • Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
  6. Motorola Nextel i880 Key Pad Replacement: 步骤 6 中的图像 1,1
    • Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
    • Secure the rest of the key pad.
  7. Motorola Nextel i880 Key Pad Replacement: 步骤 7 中的图像 1,1
    • Put the logic board back into place and reattach cable number 1.
  8. Motorola Nextel i880 Key Pad Replacement: 步骤 8 中的图像 1,1
    • Snap the front and back of the phone back together and reinsert screws 1 through 4.
结论
团队
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 138
