跳转到主内容
Motorola Nextel i880 Antenna Replacement
你所需要的
  1. Motorola Nextel i880 Antenna Replacement, Antenna: 步骤 1 中的图像 1,1
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
  2. Motorola Nextel i880 Antenna Replacement: 步骤 2 中的图像 1,1
    • Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
  3. Motorola Nextel i880 Antenna Replacement: 步骤 3 中的图像 1,1
    • Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
  4. Motorola Nextel i880 Antenna Replacement: 步骤 4 中的图像 1,1
    • Slide and secure new antenna into position. Make sure metal receiver is facing forward.
  5. Motorola Nextel i880 Antenna Replacement: 步骤 5 中的图像 1,1
    • Reattach back cover and secure all components in place.
结论
Ryan
于10/19/14注册
9 声望
撰写一个指南
团队
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 208
