本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove or replace a dead or dying battery in your Motorola Moto X Pure Edition. If your battery is swollen, take appropriate precautions.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
你所需要的
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
在这个步骤中使用的工具:Tesa 61395 Tape$5.99
Carefully pry the cover away from the phone.
First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Gently slide the point of a spudger underneath the corner of the volume button connector board, which is adhered to the battery.
Lift the board slightly to separate it from the battery.
Grasp one of the battery adhesive tabs with your fingers and slowly pull it away from the battery, towards the bottom of the phone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the midframe. For best results, pull the strip at as low an angle as possible, without snagging it on any other components.
If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
Carefully compare your new replacement part to the original part. Remove any adhesive backings before installing your new battery.
After completing this guide, calibrate your newly-installed battery.
70等其他人完成本指南。
42条评论
Rayan thank you, although I am not yet ready to replace the battery (about a year to go) yet, I would like to know if there are better batteries than those that came with the unit from the manufacturer? An upgrade that holds a better charge on a daily basis? Marty
Do you have a link to buy a battery? I've been looking but I'm still not confident with me results. Preferably one that includes the necessary tools, but so long as it's definitely the correct battery. I need to replace my battery, NOW!
Battery now available. Please see link on this page or here:Moto X Pure Edition Battery - Genuine
Has anyone bought a 3rd party battery for this phone? I got one from Germany brand name "vhbw", however it is not curved and so will not fit. It is quite soft and so am wondering if it is safe to bend such batteries? Not sure if I should risk it, though.
Alex, I bent my new battery to make it fit. It seems to be working just fine.
