当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Push the tip of a spudger under the microphone assembly clip to free it from the earpiece speaker.
If the assembly clip seems to be missing, check the speaker assembly that was removed from the previous step.
Insert the flat end of a spudger under the motherboard above the button assembly cable, and pry it out of the phone.
Be careful not to snag any cables.
The buttons may pop out of their recesses; take care not to lose them.
Gently lift the motherboard out of the phone, rotating it from the SIM slot edge of the phone.
Do not attempt to separate the motherboard entirely; it is still connected to the display by the display cable.
Lay the motherboard down to allow access to the display cable connector.
Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector.
Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
