跳转到主内容
Motorola Moto X Headphone Jack/Speaker Assembly Replacement
你所需要的
视频概述
  1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: 步骤 1 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: 步骤 1 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: 步骤 1 中的图像 3,3
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: 步骤 2 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: 步骤 2 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: 步骤 2 中的图像 3,3
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 4 中的图像 1,2 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 4 中的图像 2,2
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 5 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 5 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 5 中的图像 3,3
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  6. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 6 中的图像 1,1
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  7. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 7 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 7 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 7 中的图像 3,3
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  8. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 8 中的图像 1,1
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  9. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 9 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 9 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 9 中的图像 3,3
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 10 中的图像 1,1
    • Separate the back cover from the phone.
  11. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 步骤 11 中的图像 1,1
    • Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
  12. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 12 中的图像 1,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 12 中的图像 2,3 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: 步骤 12 中的图像 3,3
    • Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
    • Remove the headphone jack/speaker assembly.
结论
4等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,762 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
Is this the signal antenna?
I have one that says Searching for service and no matter what it won’t detect any network.
Not sure if this or the lower antenna are responsible for cellular signal.
Rafael B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 5,817
