跳转到主内容
Motorola Moto X 2nd Generation Power and Volume flex cable Replacement
你所需要的
  1. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 步骤 1 中的图像 1,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 步骤 1 中的图像 2,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 步骤 1 中的图像 3,3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 2 中的图像 1,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 2 中的图像 2,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 2 中的图像 3,3
    • Remove back cover.
  3. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 3 中的图像 1,2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 3 中的图像 2,2
    • Remove those two rubber cover.
  4. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 4 中的图像 1,2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 4 中的图像 2,2
    • Release power connecting flex connector and battery connector.
  5. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 5 中的图像 1,2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 5 中的图像 2,2
    • Twist off all 18 black torx screws and remove the middle housing from front assembly.
  6. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 6 中的图像 1,2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 6 中的图像 2,2
    • Release power flex connector from connecting flex.
  7. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 7 中的图像 1,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 7 中的图像 2,3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 7 中的图像 3,3
    • Remove securing bracket and side buttons.
  8. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 步骤 8 中的图像 1,1
    • Pry up and remove the power flex.
结论
10等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
3条评论
Followed your instructions. Volume works, power button still no go.
It clicks fine, but nothing happens..
Carlo Petermann - 回复
I have the same issue. Any ideas? Resolutions?
sagar bhale -
The screwdriver is T4 on my european moto X 2014, not T3!!
Clément Masci - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 5,090
