跳转到主内容
  1. Remove SIM card tray. Remove SIM card tray. Remove SIM card tray.
    • Remove SIM card tray.
  2. Use the eject pin to open a gap and place a guitar pick into the gap. Use the eject pin to open a gap and place a guitar pick into the gap.
    • Use the eject pin to open a gap and place a guitar pick into the gap.
  3. Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover. Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover.
    • Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover.
  4. Twist off three screws, pry up the securing bracket and remove the logo finally. Twist off three screws, pry up the securing bracket and remove the logo finally. Twist off three screws, pry up the securing bracket and remove the logo finally.
    • Twist off three screws, pry up the securing bracket and remove the logo finally.
结论
4等其他人完成本指南。
Sophia
于2014年03月25日注册
43,362 信誉积分
创作了62篇指南
So apparently, this phone was supposed to have a fingerprint scanner. To anyone who has done this repair, I'm sure you're as confused as me as to why there is a flex cable leading to the "M" logo with nothing attached. My though is that's where the scanner was going to go, and it just never happened, which also explains why the iconic Motorola M dimple is a separate part, compared to the old Moto X and the Gs and Es, which was part of the back plastic cover.
Jeff Caauwe - 回复
Where can you get the replacement part? I'm finding it difficult.
Niall Murray - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 2,366
