跳转到主内容
Motorola Moto X 2nd Generation Back Cover Replacement
你所需要的
视频概述
  1. Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Back Cover Replacement: 步骤 2 中的图像 1,3 Motorola Moto X 2nd Generation Back Cover Replacement: 步骤 2 中的图像 2,3 Motorola Moto X 2nd Generation Back Cover Replacement: 步骤 2 中的图像 3,3
    • Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Back Cover Replacement: 步骤 3 中的图像 1,2 Motorola Moto X 2nd Generation Back Cover Replacement: 步骤 3 中的图像 2,2
    • Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
    • At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
结论
19等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
3条评论
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
Hassan Almarzooq - 回复
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
[deleted] - 回复
What type of adhesive do you use to reseal the back cover?
sfcvickers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 26,111
