跳转到主内容
视频概述
  1. Remove SIM card tray. Remove SIM card tray. Remove SIM card tray.
    • Remove SIM card tray.
  2. Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap. Place the guitar pick into the gap. Place the guitar pick into the gap.
    • Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
    • Place the guitar pick into the gap.
  3. Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong. At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
    • Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
    • At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
结论
19等其他人完成本指南。
Sophia
于2014年03月25日注册
43,335 信誉积分
创作了62篇指南
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
Hassan Almarzooq - 回复
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
[deleted] - 回复
What type of adhesive do you use to reseal the back cover?
sfcvickers - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 8
总计 25,807
