跳转到主内容
Motorola Moto Q LCD Display Replacment
你所需要的
  1. Motorola Moto Q LCD Display Replacment, Back Casing: 步骤 1 中的图像 1,1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q LCD Display Replacment: 步骤 2 中的图像 1,1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q LCD Display Replacment: 步骤 3 中的图像 1,2 Motorola Moto Q LCD Display Replacment: 步骤 3 中的图像 2,2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q LCD Display Replacment: 步骤 4 中的图像 1,2 Motorola Moto Q LCD Display Replacment: 步骤 4 中的图像 2,2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q LCD Display Replacment, Camera: 步骤 5 中的图像 1,2 Motorola Moto Q LCD Display Replacment, Camera: 步骤 5 中的图像 2,2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q LCD Display Replacment: 步骤 6 中的图像 1,2 Motorola Moto Q LCD Display Replacment: 步骤 6 中的图像 2,2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q LCD Display Replacment: 步骤 7 中的图像 1,2 Motorola Moto Q LCD Display Replacment: 步骤 7 中的图像 2,2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q LCD Display Replacment: 步骤 8 中的图像 1,2 Motorola Moto Q LCD Display Replacment: 步骤 8 中的图像 2,2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q LCD Display Replacment, LCD Display: 步骤 9 中的图像 1,2 Motorola Moto Q LCD Display Replacment, LCD Display: 步骤 9 中的图像 2,2
    • Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
    • Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
    • Note: the orange band is connected to the logic board by a small connector.
  10. Motorola Moto Q LCD Display Replacment: 步骤 10 中的图像 1,3 Motorola Moto Q LCD Display Replacment: 步骤 10 中的图像 2,3 Motorola Moto Q LCD Display Replacment: 步骤 10 中的图像 3,3
    • Wedge the spudger in between the logic board and the front casing and gently lift while pulling away from the orange ribbon.
    • Note: it is easier to remove the logic board by prying upwards near the top of left corner phone.
  11. Motorola Moto Q LCD Display Replacment: 步骤 11 中的图像 1,3 Motorola Moto Q LCD Display Replacment: 步骤 11 中的图像 2,3 Motorola Moto Q LCD Display Replacment: 步骤 11 中的图像 3,3
    • Wedge the plastic opening tool between the LCD screen and the metal casing holding it in and lift gently.
    • Note: the LCD screen is also held in place by a silver tape. Simply pull the screen from one side to other to remove the screen completely.
结论
另外一个人完成了本指南。
Luis Herrera
于01/21/10注册
76 声望
创作了4篇指南
团队
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G33
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,017
