跳转到主内容
Motorola Moto Q Camera Replacement
你所需要的
  1. Motorola Moto Q Camera Replacement, Back Casing: 步骤 1 中的图像 1,1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Camera Replacement: 步骤 2 中的图像 1,1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Camera Replacement: 步骤 3 中的图像 1,2 Motorola Moto Q Camera Replacement: 步骤 3 中的图像 2,2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Camera Replacement: 步骤 4 中的图像 1,2 Motorola Moto Q Camera Replacement: 步骤 4 中的图像 2,2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Camera Replacement, Camera: 步骤 5 中的图像 1,2 Motorola Moto Q Camera Replacement, Camera: 步骤 5 中的图像 2,2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Camera Replacement: 步骤 6 中的图像 1,2 Motorola Moto Q Camera Replacement: 步骤 6 中的图像 2,2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Camera Replacement: 步骤 7 中的图像 1,2 Motorola Moto Q Camera Replacement: 步骤 7 中的图像 2,2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Camera Replacement: 步骤 8 中的图像 1,2 Motorola Moto Q Camera Replacement: 步骤 8 中的图像 2,2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
结论
另外一个人完成了本指南。
Dave Uth
于01/20/10注册
35 声望
撰写一个指南
团队
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G33
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,954
