跳转到主内容
Motorola Moto Q Back Casing Replacement
你所需要的
  1. Motorola Moto Q Back Casing Replacement, Back Casing: 步骤 1 中的图像 1,1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Back Casing Replacement: 步骤 2 中的图像 1,1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Back Casing Replacement: 步骤 3 中的图像 1,2 Motorola Moto Q Back Casing Replacement: 步骤 3 中的图像 2,2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Back Casing Replacement: 步骤 4 中的图像 1,2 Motorola Moto Q Back Casing Replacement: 步骤 4 中的图像 2,2
    • Gently lift and remove the back casing.
结论
Luis Herrera
于01/21/10注册
52 声望
创作了4篇指南
团队
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G33
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 5,163
