跳转到主内容
Motorola Moto G7 Speaker Replacement
你所需要的
  1. Motorola Moto G7 Speaker Replacement, Screen: 步骤 1 中的图像 1,3 Motorola Moto G7 Speaker Replacement, Screen: 步骤 1 中的图像 2,3 Motorola Moto G7 Speaker Replacement, Screen: 步骤 1 中的图像 3,3
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Speaker Replacement: 步骤 2 中的图像 1,1
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Speaker Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Speaker Replacement: 步骤 4 中的图像 1,3 Motorola Moto G7 Speaker Replacement: 步骤 4 中的图像 2,3 Motorola Moto G7 Speaker Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
  5. Motorola Moto G7 Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Motorola Moto G7 Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Motorola Moto G7 Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Remove three 3.7mm T3 Torx screws from the bottom of the phone.
    • Use the spudger to gently lift the speaker out of the phone.
结论
3等其他人完成本指南。
Peter Nelson
于01/23/20注册
742 声望
创作了3篇指南
团队
Cal Poly, Team S19-G6, White Winter 2020 Cal Poly, Team S19-G6, White Winter 2020 的会员
CPSU-WHITE-W20S19G6
4 名成员
创作了20篇指南
一条评论
Could you perhaps offer any advice on how to source one of these bottom-ported speakers?
Kevin Lettelleir - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 4,246
