跳转到主内容
Motorola Moto G7 Plus Speaker Replacement
你所需要的
  1. Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: 步骤 1 中的图像 1,2 Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: 步骤 1 中的图像 2,2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: 步骤 2 中的图像 1,2 Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: 步骤 2 中的图像 2,2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Speaker Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Plus Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: 步骤 4 中的图像 1,2 Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: 步骤 4 中的图像 2,2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Motorola Moto G7 Plus Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
  6. Motorola Moto G7 Plus Speaker Replacement: 步骤 6 中的图像 1,3 Motorola Moto G7 Plus Speaker Replacement: 步骤 6 中的图像 2,3 Motorola Moto G7 Plus Speaker Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
    • A medium amount of force may be required.
结论
Javier Guerra
于02/10/20注册
300 声望
撰写一个指南
团队
Cal Poly, Team S22-G5, Regan Winter 2020 Cal Poly, Team S22-G5, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G5
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 2,329
