跳转到主内容
Motorola Moto G7 Plus Motherboard Replacement
你所需要的
  1. Motorola Moto G7 Plus Motherboard Replacement, Remove the Screen: 步骤 1 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement, Remove the Screen: 步骤 1 中的图像 2,2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Motherboard Replacement, Remove the Display Cable Cover: 步骤 2 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement, Remove the Display Cable Cover: 步骤 2 中的图像 2,2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Motherboard Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Motherboard Replacement, Separate the Display From the Phone: 步骤 4 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement, Separate the Display From the Phone: 步骤 4 中的图像 2,2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Motorola Moto G7 Plus Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Motorola Moto G7 Plus Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Remove thirteen 2.7mm screws holding the rear camera housing plate with a T5 Torx screwdriver.
    • Use the opening pick or spudger to lift the plate from the motherboard.
  6. Motorola Moto G7 Plus Motherboard Replacement: 步骤 6 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to disconnect the three connectors from the motherboard.
    • Lift the rear camera and copper plate from the board.
  7. Motorola Moto G7 Plus Motherboard Replacement: 步骤 7 中的图像 1,2 Motorola Moto G7 Plus Motherboard Replacement: 步骤 7 中的图像 2,2
    • Insert the plastic opening tool under the right and top of the motherboard, and pry it free from the body.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 1,540
