跳转到主内容
Motorola Moto G7 Plus Fingerprint Sensor Replacement
你所需要的
  1. Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 步骤 1 中的图像 1,2 Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 步骤 1 中的图像 2,2
    • Insert an opening pick under the screen, starting at the top of the phone.
    • Work the pick along the edges of the phone while placing them in the corners.
    • After placing the picks along the edge of the screen, refer to step 2.
    • Unlike the front of the phone, it is fine to use the picks on the left side of the phone because there are no cables that can be damaged.
    • While not necessary, applying a heat gun will weaken the adhesive, making this step significantly easier and quicker.
  2. Motorola Moto G7 Plus Fingerprint Sensor Replacement: 步骤 2 中的图像 1,2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: 步骤 2 中的图像 2,2
    • Loosen the adhesive by cutting along the sides of the phone with the Jimmy Knife and prop open the back.
    • It is possible to use the opening pick to remove adhesive from the edges of the back case, however, it is much more difficult.
  3. Motorola Moto G7 Plus Fingerprint Sensor Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: 步骤 3 中的图像 2,2
    • The fingerprint sensor is now visible and can be replaced.
    • Remove the sensor cable with the metallic cover on top.
    • No tools or screws are necessary to remove the cable as it should easily come right off.
结论
另外一个人完成了本指南。
Arun Ganesh
于02/10/20注册
121 声望
撰写一个指南
团队
Cal Poly, Team S22-G5, Regan Winter 2020 Cal Poly, Team S22-G5, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G5
5 名成员
创作了17篇指南
3条评论
Hello, the connector of the fingerprint scanner isn’t actually detachable from the back. In order to reach it you need to take the screen off, so this tutorial is only partially helpful for fixing the fingerprint scanner.
Danny Remi - 回复
hello y need a original battery cover for my motorola moto g7 plus can you help me $g$
Miguel Plascencia guzman - 回复
Where can I order the sensor from?
Sourabh Kapur - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 3,489
