跳转到主内容
Motorola Moto G7 Play Fingerprint Sensor Replacement
你所需要的
  1. Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 2 中的图像 1,1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Fingerprint Sensor Replacement, Fingerprint Sensor: 步骤 4 中的图像 1,1
    • Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 5 中的图像 1,1
    • Lift motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed
  6. Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 6 中的图像 1,2 Motorola Moto G7 Play Fingerprint Sensor Replacement: 步骤 6 中的图像 2,2
    • Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
    • Remove the fingerprint scanner from the device.
结论
3等其他人完成本指南。
Monserath Casillas
于02/10/20注册
1,146 声望
创作了5篇指南
团队
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G4
5 名成员
创作了12篇指南
一条评论
Do you need to replace the adhesive on the rear cover? Or is it reusable?
wtwolfe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 1,615
