跳转到主内容
Motorola Moto G7 Battery Replacement
你所需要的
  1. Motorola Moto G7 Battery Replacement, Screen: 步骤 1 中的图像 1,3 Motorola Moto G7 Battery Replacement, Screen: 步骤 1 中的图像 2,3 Motorola Moto G7 Battery Replacement, Screen: 步骤 1 中的图像 3,3
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
    I just destroyed my screen by dividing it in two parts. You have to be extra careful to dig deep enough in the first step, so you lift the entire screen unit!
    Michael - 回复
    Thanks... I almost did just that!
    Carlisle “Mike” Wick - 回复
  2. Motorola Moto G7 Battery Replacement: 步骤 2 中的图像 1,1
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Battery Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Battery Replacement: 步骤 4 中的图像 1,3 Motorola Moto G7 Battery Replacement: 步骤 4 中的图像 2,3 Motorola Moto G7 Battery Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
    This would also be a good place to disconnect the battery connector, which is right under the display connector.
    Daniel Kim - 回复
    At this point, one could remove the battery. I don't see why the remaining steps are necessary.
    Kimball - 回复
    there is one more piece to remove here. 3 black screws (T3 but longer) and the part visible above the battery on the last image above. Empty space on the top of the image in step 5.
    Tadeusz Liszka - 回复
  5. Motorola Moto G7 Battery Replacement, Camera: 步骤 5 中的图像 1,3 Motorola Moto G7 Battery Replacement, Camera: 步骤 5 中的图像 2,3 Motorola Moto G7 Battery Replacement, Camera: 步骤 5 中的图像 3,3
    • Remove by the six 2.7mm T3 Torx screws from the metal panel above the battery.
    • Wedge a spudger between the SD card tray and the metal plate, and use a medium amount of force to pry up the plate.
  6. Motorola Moto G7 Battery Replacement: 步骤 6 中的图像 1,1
    • Use a spudger beneath the right side of the connector to detach it.
  7. Motorola Moto G7 Battery Replacement: 步骤 7 中的图像 1,3 Motorola Moto G7 Battery Replacement: 步骤 7 中的图像 2,3 Motorola Moto G7 Battery Replacement: 步骤 7 中的图像 3,3
    • Detach the two small black and white connectors on either side of the camera using a spudger.
    • Remove the camera from the smartphone.
  8. Motorola Moto G7 Battery Replacement, Motherboard: 步骤 8 中的图像 1,3 Motorola Moto G7 Battery Replacement, Motherboard: 步骤 8 中的图像 2,3 Motorola Moto G7 Battery Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Use the SIM card removal bit to remove the SIM card tray.
  9. Motorola Moto G7 Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the fingerprint scanner connector from the motherboard by levering the spudger underneath the connector corner.
    The circled part is not the connector, it’s the cable. The connector is just above what the picture shows.
    Rich Kosiba - 回复
  10. Motorola Moto G7 Battery Replacement: 步骤 10 中的图像 1,1
    • Use a T3 Torx screwdriver to remove the four 2.3mm screws from the bottom and right sides of the phone.
    Don’t forget to disconnect the ribbon cable above the screw second from the right!
    Daniel Kim - 回复
  11. Motorola Moto G7 Battery Replacement: 步骤 11 中的图像 1,2 Motorola Moto G7 Battery Replacement: 步骤 11 中的图像 2,2
    • Lever the spudger underneath the motherboard above the battery.
    • Use a medium amount of force to remove the motherboard from the rest of the phone assembly.
    The microphone/speaker holds the motherboard in. There are no directions here to remove it. It’s still attached in Step 4 but gone in Step 5.
    1. In the lower left corner of the phone, there are three black T5 screws that need to be removed.
    2. Use your spudger to lift it out of the phone. There are no cables to detach. It has two contacts that press against the motherboard.
    3. There is a small white piece of plastic that sits at the edge of the motherboard. The part we just removed holds it in so there should be nothing attaching it to the phone now. Remove it.
    (Note: Step 8 of the guide for replacing the motherboard in this phone explains this step.)
    Rich Kosiba - 回复
  12. Motorola Moto G7 Battery Replacement, Battery: 步骤 12 中的图像 1,2 Motorola Moto G7 Battery Replacement, Battery: 步骤 12 中的图像 2,2
    • Pry the battery out of the case using a spudger beneath the top of the battery.
    • You can place an iOpener on the opposite side of the phone to apply indirect heat to loosen the battery's adhesive.
    • Do not use metal tools for this part because the battery can be punctured and can potentially catch fire.
结论
6等其他人完成本指南。
Saba Jafroodi
于02/04/20注册
219 声望
创作了2篇指南
团队
Cal Poly, Team S19-G6, White Winter 2020 Cal Poly, Team S19-G6, White Winter 2020 的会员
CPSU-WHITE-W20S19G6
4 名成员
创作了20篇指南
16条评论
I don’t know what phone you are replacing a battery on here, but it looks nothing like my Motorola G7, which has a JK50 battery in it. The JK50 is NOT interchangeable with the JG30 you have pictured here and available to order.
Jeanette Carey - 回复
The Moto G7 has many variations, including the G7 Play and the G7 Power, which is the model that takes the JK50. These instructions are for the plain vanilla G7.
Jim Grybowski -
This is a careless incomplete guide. It skips crucial steps, like removing the speaker subassembly (which the photos clearly show was done but not even mentioned), the buttons connector, and last but not least the battery connector itself. I also have wound up with two mystery rubberized parts which fell out at two separate points in disassembly, which are also never mentioned and which I will now have to black-box to figure out where they came from.
Vulcan Tourist - 回复
It also glosses over the reassembly, omitting it entirely in fact, thus failing to remind the reader, for instance, not to overlook the fingerprint reader’s connector when reinserting the motherboard and paying heed of the several tabs - and rubber parts which must be considered when reattaching that metal shield over the camera.
Vulcan Tourist -
Also not mentioned is any suggestion how to replace the original rubberized adhesive “gasket” that attaches the front glass, which is supposed to provide some waterproofness as well as adhesion. In my instance that was compromised before I even started: the battery inflated with gas and bowed the glass front outward. Thank goodness Corning has chosen to evolve Gorilla Glass to be more flexible rather than more scratch-resistant and more brittle, otherwise I’d have had a cracked front. (That battery inflation is now the second occurrence in a second Motorola phone; I am officially spooked of Motorola phones now.)
Vulcan Tourist -
@vulcantourist
Yep, about an hour ago my battery and screen just inflated & bowed as well. Should I open it now and disconnect or is it safe to wait till replacement? What adhesive is needed to re apply the screen?
seededcrown - 回复
@seededcrown:
I’m uncertain whether I can obtain a 3rd party replacement for the screen’s gasket, or whether I’m expected to just use some form of gel adhesive. I really don’t want to do the latter, it’s inferior! Since I can’t commit to anything permanent, I’ve literally Scotch-taped the screen for now. :-/
The OLED display began suffering horribly from burn-in less than a year into ownership. That’s a bonus in addition to the battery near-exploding. I’d replace it with a non-Motorola 5G phone, but there’s no money at all to do it.
If I find a replacement for the gasket or conceive another solution, I’ll try to share my decision here. Please do the same if you find something first. If your degree of bowing is substantial already, I’d rush to get a new battery and install it ASAP, before the existing battery gets worse! I bought my battery from Amazon; I’d share a link, but I’m uncertain if that’s encouraged. I’m sure there are plenty of acceptable alternatives. Hopefully you get to avoid duct tape.
Vulcan Tourist -
How have you progressed with fixing your phone?
Vulcan Tourist -
This is apparently how you fix the display and front glass back in place: https://www.amazon.com/s?k=2mm+adhesive+.... It’s very narrow 2mm adhesive tape made for the purpose. I’m unsure whether it’s as effective at sealing out water as the original, but it’s not like we have a choice (aside from buying new phones).
Vulcan Tourist -
Definitely missing a few steps, such as removing the speaker and a little white/red plastic thing, detaching several of the small connectors, and reassembly (especially re-connecting those little connectors).
Stefan Lasiewski - 回复
Inaccurate and misleading. Opening the case was the most difficult step - and - related to it, closing the case did not work. Unlike other phones that just click back the Moto G7 requires an adhesive to stay shut. The adhesive made it very difficult to open and without it, the phone stays partially open. The battery too is held in place with that same tight adhesive making it impossible to remove without bending the battery and risk damaging neighboring structures. I would not recommend replacing the battery on a Moto G7!
Jerry - 回复
I tried one of the many adhesive 1mm tapes offered via Amazon, but it overstated its adhesive properties and it was insufficient to the task: ever since the battery replacement I've been having to repeatedly press down the front glass when it begins to bow itself loose. Recently I finally decided it was time to rectify that and bought some "B-7000" adhesive fluid via Amazon. The plastic tube has a syringe-needle-like applicator tip which should make it rather easy to apply it to the inner frame edge and hopefully reseal it finally.
Regarding the battery, yes, it's secured with very strong adhesive tape, but you CAN remove the battery with considerable care. I did it. That was not one of my several complaints about this poorly scripted guide.
Vulcan Tourist -
Guide worked great for me. I only had to remove the three screws for the battery connector and the six screws for the camera, and removing the camera was only really needed to make space for tools to pry out the battery. Mine was glued in like a MFer, and the tip about applying heat once I got a bit of a gap really made all the difference, my wife's hair dryer on low heat was plenty good enough.
There are a mind numbing number of variations of the Moto G(7) getting the exact model number from settings is crucial to getting the correct battery and instructions.
Phone booted right up, battery initially was like 15% after it booted, charged up to 100% while we were relaxing in the hot tub, now its off the charger. Battery vendor says it needs a few "cycles" to get full capacity, we'll see.
The factory battery was swelled up enough that opening the case had pretty much already happened, so far $23 for a battery sure beats $250+ for a new phone, this one still meets all my wife's needs. No issues closing it, the case helps alleviate the need for replacing the glue.
Wally Bkg - 回复
This explanation assumes you are accessing the phone through the front glass. This is not what you would do just to change the battery where you would remove the rear panel.
Gary Cole - 回复
Try Loctite Go2. You then should be able to use a little heat if opening is needed in the future.
Jim Metz - 回复
Loctite 480 might be a better choice.
Vulcan Tourist -
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 120
过去 30 天: 543
总计 27,353
