跳转到主内容
Motorola Moto G5s Plus Display Replacement
你所需要的
  1. Motorola Moto G5s Plus Display Replacement, Display: 步骤 1 中的图像 1,3 Motorola Moto G5s Plus Display Replacement, Display: 步骤 1 中的图像 2,3 Motorola Moto G5s Plus Display Replacement, Display: 步骤 1 中的图像 3,3
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Display Replacement: 步骤 2 中的图像 1,2 Motorola Moto G5s Plus Display Replacement: 步骤 2 中的图像 2,2
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Display Replacement: 步骤 3 中的图像 1,3 Motorola Moto G5s Plus Display Replacement: 步骤 3 中的图像 2,3 Motorola Moto G5s Plus Display Replacement: 步骤 3 中的图像 3,3
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Display Replacement: 步骤 4 中的图像 1,3 Motorola Moto G5s Plus Display Replacement: 步骤 4 中的图像 2,3 Motorola Moto G5s Plus Display Replacement: 步骤 4 中的图像 3,3
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Display Replacement: 步骤 5 中的图像 1,2 Motorola Moto G5s Plus Display Replacement: 步骤 5 中的图像 2,2
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Display Replacement: 步骤 6 中的图像 1,2 Motorola Moto G5s Plus Display Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Display Replacement: 步骤 7 中的图像 1,2 Motorola Moto G5s Plus Display Replacement: 步骤 7 中的图像 2,2
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Display Replacement: 步骤 8 中的图像 1,2 Motorola Moto G5s Plus Display Replacement: 步骤 8 中的图像 2,2
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
结论
8等其他人完成本指南。
Kevin George
于10/08/18注册
1,072 声望
创作了4篇指南
团队
Cal Poly, Team S4-G5, White Fall 2018 Cal Poly, Team S4-G5, White Fall 2018 的会员
CPSU-WHITE-F18S4G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 36
总计 4,666
