跳转到主内容
Motorola Moto G5 Vibration Motor Replacement
你所需要的
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G5 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: 步骤 2 中的图像 1,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 2 中的图像 2,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 2 中的图像 3,3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: 步骤 3 中的图像 1,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 3 中的图像 2,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: 步骤 4 中的图像 1,2 Motorola Moto G5 Vibration Motor Replacement: 步骤 4 中的图像 2,2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Moto G5 Vibration Motor Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: 步骤 7 中的图像 1,1
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: 步骤 9 中的图像 1,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 9 中的图像 2,3 Motorola Moto G5 Vibration Motor Replacement: 步骤 9 中的图像 3,3
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: 步骤 10 中的图像 1,1
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: 步骤 11 中的图像 1,1
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
结论
7等其他人完成本指南。
Miles Cobb
于01/24/18注册
370 声望
撰写一个指南
团队
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G3
4 名成员
创作了16篇指南
一条评论
Is this also where the mic is located?
Matt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 3,394
