跳转到主内容
Motorola Moto G5 Rear Facing Camera Replacement
你所需要的
  1. Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 2 中的图像 1,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 2 中的图像 2,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 3 中的图像 1,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 3 中的图像 2,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Rear Facing Camera Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Moto G5 Rear Facing Camera Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 1,2 Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 2,2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 8 中的图像 1,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 8 中的图像 2,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 8 中的图像 3,3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Rear Facing Camera Replacement: 步骤 9 中的图像 1,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 9 中的图像 2,3 Motorola Moto G5 Rear Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
结论
3等其他人完成本指南。
Kristina Tran
于01/24/18注册
559 声望
创作了2篇指南
团队
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G3
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,731
