跳转到主内容
Motorola Moto G5 Motherboard Replacement
你所需要的
  1. Motorola Moto G5 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G5 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Motherboard Replacement: 步骤 2 中的图像 1,3 Motorola Moto G5 Motherboard Replacement: 步骤 2 中的图像 2,3 Motorola Moto G5 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Motherboard Replacement: 步骤 3 中的图像 1,3 Motorola Moto G5 Motherboard Replacement: 步骤 3 中的图像 2,3 Motorola Moto G5 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Motherboard Replacement: 步骤 4 中的图像 1,2 Motorola Moto G5 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Motherboard Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Moto G5 Motherboard Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: 步骤 7 中的图像 1,2 Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: 步骤 7 中的图像 2,2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Motherboard Replacement: 步骤 8 中的图像 1,3 Motorola Moto G5 Motherboard Replacement: 步骤 8 中的图像 2,3 Motorola Moto G5 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Motherboard Replacement: 步骤 9 中的图像 1,3 Motorola Moto G5 Motherboard Replacement: 步骤 9 中的图像 2,3 Motorola Moto G5 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Unplug the back connector from the motherboard using tweezers.
结论
11等其他人完成本指南。
Luis Garcia
于01/24/18注册
307 声望
撰写一个指南
团队
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G3
4 名成员
创作了16篇指南
2条评论
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - 回复
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 51
总计 6,222
