简介
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
remove 16 phillips 00 screws
the two screws on either side of the battery (red color on thread) are shorter than the other screws (blue color on thread)
don't forget this one hiding underneath this sticker
no screw here
remove the inner back plate
disconnect antenna cable from motherboard with a spudger.
disconnect screen and digitiser cables with a spudger.
remove rear facing camera with a spudger
remove phillips 00 screw
Remove motherboard. this cable is still connected, you must disconnect it as you remove the motherboard.
disconnect antenna and data cable
remove philips 00 screws
Remove usb board and vibrator together.
Peel off black sticker under battery compartment.
peel off data cable
remove antenna wire
remove speaker
10等其他人完成本指南。
4条评论
what if the new screen does not turn on or light up when you turn the phone on??? what part is causing that issue??
lilmizzipf - 回复
I’ve just wrapped up an abortive attempt to replace the screen on a friend’s G4 Play. It was aborted because the screen I bought off of ebay has only one digitizer connection on the upper left of the screen but my friend’s model has the two connections pictured in step 4 of this procedure. I can’t find an XT1601 screen on ebay or aliexpress or anywhere else that sports the twin connectors. What model of phone was this? Any clues on how to track this down?
@jrhooker that’s the button cable
good steps Michael + my name is Michael too
