跳转到主内容
Motorola Moto G4 Play Rear Camera Replacement
你所需要的
  1. Motorola Moto G4 Play Rear Camera  Replacement, Battery: 步骤 1 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement, Battery: 步骤 1 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement, Battery: 步骤 1 中的图像 3,3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 2 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 2 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 2 中的图像 3,3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 3 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 3 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 3 中的图像 3,3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Rear Camera  Replacement, Midframe: 步骤 4 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement, Midframe: 步骤 4 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement, Midframe: 步骤 4 中的图像 3,3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 5 中的图像 1,2 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 6 中的图像 1,1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 7 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 7 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement: 步骤 7 中的图像 3,3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Rear Camera  Replacement, Rear Camera: 步骤 8 中的图像 1,3 Motorola Moto G4 Play Rear Camera  Replacement, Rear Camera: 步骤 8 中的图像 2,3 Motorola Moto G4 Play Rear Camera  Replacement, Rear Camera: 步骤 8 中的图像 3,3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
  9. Motorola Moto G4 Play Rear Camera  Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
结论
Paola Rossi
于02/15/18注册
502 声望
创作了3篇指南
团队
USF Tampa, Team S17-G4, Boczar Spring 2018 USF Tampa, Team S17-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 991
