跳转到主内容
Motorola Moto G4 Lens Replacement
你所需要的
  1. Motorola Moto G4 Lens Replacement, Lens: 步骤 1 中的图像 1,2 Motorola Moto G4 Lens Replacement, Lens: 步骤 1 中的图像 2,2
    • Place your thumb in the indent located at bottom left corner of the back cover.
    • The cover will pop up and begin to lift
    • Continue to slide your fingers up the sides to remove the back cover
  2. Motorola Moto G4 Lens Replacement: 步骤 2 中的图像 1,2 Motorola Moto G4 Lens Replacement: 步骤 2 中的图像 2,2
    • Remove the gray plastic surrounding the camera lens with a pair of tweezers.
    • There will be a lot of glue and you may have to pull hard on the plastic piece
  3. Motorola Moto G4 Lens Replacement: 步骤 3 中的图像 1,2 Motorola Moto G4 Lens Replacement: 步骤 3 中的图像 2,2
    • Slide a pair of tweezers under and around the lens to loosen it.
    • Pulls the lens towards you to remove.
    • There will be glue under the lens. You may have to pull hard to remove the lens
结论
6等其他人完成本指南。
Kierra Schau
于09/28/17注册
1,511 声望
创作了4篇指南
团队
USF Tampa, Team S11-G2, Passmore Fall 2017 USF Tampa, Team S11-G2, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G2
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,975
