跳转到主内容
Motorola Moto G3 Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: 步骤 1 中的图像 1,2 Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Motherboard  Replacement: 步骤 4 中的图像 1,3 Motorola Moto G3 Motherboard  Replacement: 步骤 4 中的图像 2,3 Motorola Moto G3 Motherboard  Replacement: 步骤 4 中的图像 3,3
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 1,3 Motorola Moto G3 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 2,3 Motorola Moto G3 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 3,3
    • With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Motherboard  Replacement: 步骤 6 中的图像 1,2 Motorola Moto G3 Motherboard  Replacement: 步骤 6 中的图像 2,2
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
    • Remove the motherboard from the device.
结论
3等其他人完成本指南。
Irkan Notta
于03/19/18注册
1,034 声望
创作了7篇指南
团队
Baylor, Team S5-G3, Williams Spring 2018 Baylor, Team S5-G3, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G3
3 名成员
创作了9篇指南
一条评论
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
All you need to Know (SAMMY) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 472
