跳转到主内容
Motorola Moto G Stylus 4G (2023) Screen Replacement
你所需要的
  1. Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 3 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 3 中的图像 2,2
    • Use the opening pick along the edges to separate the camera lens glass from the board.
  4. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 4 中的图像 1,1
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 5 中的图像 1,1
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 6 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 6 中的图像 2,2
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 7 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 7 中的图像 2,2
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 8 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 8 中的图像 2,2
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Screen Replacement, Screen: 步骤 9 中的图像 1,1
    • Apply heat using a heat gun to soften the adhesive around the edges of the screen.
    • Avoid overheating to prevent damage to the device.
  10. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 10 中的图像 1,2 Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 10 中的图像 2,2
    • Insert a Jimmy into the crevice between the screen and the rest of the phone.
    • Work around the edges to gently pry the screen away from the phone.
    • Be careful to avoid glass fragments from the broken screen.
  11. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 11 中的图像 1,1
    • Use a spudger to disconnect the screen connectors from the motherboard.
    • Remove any screws that are holding the screen in place.
  12. Motorola Moto G Stylus 4G (2023) Screen Replacement: 步骤 12 中的图像 1,1
    • Remove the screen from the phone.
    • Clean the frame of any adhesive residue or glass shards.
    • Align the new screen to check its fit to the frame. Place the new screen with new adhesive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 127
总计 239
