跳转到主内容
Motorola Moto G Power (2021) Frameless LCD Replacement
你所需要的
  1. Motorola Moto G Power (2021) Frameless LCD Replacement, LCD (Frameless): 步骤 1 中的图像 1,2 Motorola Moto G Power (2021) Frameless LCD Replacement, LCD (Frameless): 步骤 1 中的图像 2,2
    • Heat up the back of the G Power with a heat gun or iOpener
    • Once the adhesive has softened, insert an opening pick and slide it carefully around the perimeter of the phone to open it.
    • Do not apply too much heat or pressure when prying. You risk bending the plastic back cover.
  2. Motorola Moto G Power (2021) Frameless LCD Replacement, remove plastic cover: 步骤 2 中的图像 1,1
    • Remove the 19 Phillips screws shown on the midframe.
  3. Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 3 中的图像 1,3 Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 3 中的图像 2,3 Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 3 中的图像 3,3
    • Use a prying tool to open up the plastic cover plates.
    • If you're using a Jimmy or other metal tool, be careful to not mar the plastic.
  4. Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: 步骤 4 中的图像 1,3 Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: 步骤 4 中的图像 2,3 Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: 步骤 4 中的图像 3,3
    • Unplug the battery connector with a spudger
    • Apply 100% isopropyl alcohol to the edges of the battery. Wait one minute to let the alcohol loosen the adhesive.
    • Pry the battery up carefully. Remove & set aside.
  5. Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: 步骤 5 中的图像 1,3 Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: 步骤 5 中的图像 2,3 Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: 步骤 5 中的图像 3,3
    • heat lcd(can use decent amount of heat to remove)
    • insert opening tool and slide around the perimeter of the LCD to slice the adhesive
    • clean off old adhesive, then apply new glue(either double sided sticky tape or adhesive)
  6. Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 6 中的图像 1,3 Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 6 中的图像 2,3 Motorola Moto G Power (2021) Frameless LCD Replacement: 步骤 6 中的图像 3,3
    • plug in new LCD cable
    • insert battery and plug in the battery connector
  7. Motorola Moto G Power (2021) Frameless LCD Replacement, put phone back together: 步骤 7 中的图像 1,1
    • put plastic covers on and screw them in
    • remove most of the old adhesive
    • apply either double sided sticky tape or adhesive glue and put the plastic back cover on
    • if it is not sitting well try to heat it up and press it in a phone press or in between heavy books
结论
You did it!
2等其他人完成本指南。
ryley niemi
于02/05/21注册
259 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 89
总计 2,957
